What can cause misfires like this?
I have misfires on cylinders 2 and 6 constantly. I have monitored it with Atap at idle and all the other cylinders aren't as bad. I swapped the plug wires on them to make sure I had the coil wiring right (I messed up the wiring when I did a coil relocation, as in which plug went to which cylinder). It starts fine and sits idling fine for about 10 seconds, then I hear loud popping that isn't constant and sounds like it did when I had the coil pack wiring messed up. But it isn't constant, which leads me to believe it is only cylinders 2 and 6. The coil on #6 is new too. I don't think there is any arcing, but I could be wrong. I have them relocated with the Jay Fisher kit. Could them being too close to the fuel rail be causing a problem, could that be an arc point? Any clues what it coule be? Thanks a lot!! This is the only thing keeping my car down now.
Re: What can cause misfires like this?
I like the 4200, I didn't get to track test it before I installed the cam though. It's a very tight converter with the 2.7 STR.
ttt
ttt
