Trunk rattles bad
Ive tighten everything in that area, but the noise sounds like the rear trunk rattling up and down only when I hit a bump or something...very annoying,
Originally Posted by Javictory
every time I hit a bump or something the back trunk rattles bad...1997 trans am
Another thing you can try is adjusting the two rubber bumpers. If you look at them you will see they are actually threaded in. If you back them out a little that might make it shut tighter.
I am getting an intermittent noise from back there too, I think in my car it might actually be the amp.
