a/c question
Old 07-24-2007, 09:42 PM
sniffin94's Avatar
Default a/c question
I figured my freon was low because the air stopped blowing cold. I bought a kit with a gauge and the psi in the a/c system says danger. It has way too much pressure in the system. Anyone know what I need to replace to get the a/c working again? It's hot as hell in south florida right now and I am dying. Thanks in advance
Old 07-24-2007, 09:46 PM
JEB Garner's Avatar
I would suggest that you take it to an A/C specialist and let the experts fix the problem.
Old 07-24-2007, 10:13 PM
krayzie7th's Avatar
yea i would take it to and a/c place because you need to take all the freon out of the system and put the right amount.Those kits arent going to be that great.
Old 07-25-2007, 11:13 AM
crapyboy750's Avatar
i think u may have put a hole in the line i had the same problem and $700 later i had cold air again.
Old 07-25-2007, 03:02 PM
blkbird's Avatar
Your symptoms could mean a number of things.
Old 07-25-2007, 03:09 PM
2001NBMZ28's Avatar
Is it reading that high with the compressor running, or just when you put the gauge on? Thinking you might be reading the static pressure. Static you'll see around 100 psi depending on the ambient air temp.
