Which MAF is better Z06 85mm or SLP 85mm???
Old 05-18-2003, 11:40 AM
andy98Z's Avatar
Default Which MAF is better Z06 85mm or SLP 85mm???
I need to buy one for my 422ci, which should I buy? same price,
Old 05-18-2003, 11:46 AM
SScam68's Avatar
Default Re: Which MAF is better Z06 85mm or SLP 85mm???
I think they are the same.
From my understanding SLP takes a ZO6 MAF and calibrates if for the F-bod.
Old 05-18-2003, 11:55 AM
MIGHTYMOUSE's Avatar
unless you are using ls1 edit definitely dont use the zo6 one because you cannot calibrate it in the computer.. and for a 98 car the computer can only read to 11250hz anyway so either one will only be capable of flowing as much as the stock meter..
i have had both and use ls1 edit and currently use my stock meter.
Old 05-18-2003, 04:31 PM
andy98Z's Avatar
sscam28-LS1Speed sells both the z06 and SLP for $149 for ls1s so I dont think this is the case.
Mightymouse-Thanks its a 2000 SS.
So if they are both calibrated for an LS1 I should still go with the SLP?
