Muffler in the I pipe?
I recently installed AR longtubes with cats and I have a GMMG catback. The sound and performance is awesome, but I've been debating whether I shoud add something to the I to turn the volume down a notch. Any thoughts?
I installed this power pack in mine, going "against the grain". Took all my rasp away, made the exhaust deeper and over 45mph you can barely hear my GMMG anymore.
Travis
Travis
I have true duals with sweet thunder mufflers (similar to those power packs). I wouldn't say that it's quiet though. This may be different if you are adding it in addition to the already existing mufflers in the factory location, however. I've also heard of guys using Borla XR-1 mufflers and Moroso Spiral Flow mufflers.
Be sure to check out:
http://www.ls1sounds.com
http://video.ls1tech.com
For sound clips. Good luck.
Thanks for the replies. I'm thinking of doing exactly what you did Travis, but maybe with a shorter length if they'll make one for me. Your setup sounds similar to the Braxton (SP?) chambered catback that pre-dated the GMMG. I just dont want to lose any HP by adding another chamber.
