Fuel injector questions...
Long post, but I really need your guys' help! The other day, I noticed that my car hesitates before going. It hesitates just a little and then it takes off like normal. I checked the throttle body and I went ahead and cleaned it while I was at it, so I don't think the TB is the issue. Now, I'm starting to think it might be my fuel injectors.
Here are some questions I have...
1. Is a certain # injector more prone to go out than any of the others?
2. How easy is it to remove and check them?
3. If they are cruddy looking, how do I clean them out?
thanks...
thanks...
very easy to remove, you can have them cleaned and flow tested it's usually $12-15 an injector.
If you are running any injector at more than 80% duty cycle, they are prone to failure.
