Western Members CA, AZ, NV, UT, CO, NM, HI
Rear End, Rotors, Calipers
Old 07-30-2007, 08:10 PM
1998LS1SS's Avatar
Default Rear End, Rotors, Calipers
Everything located in California near LA. Offers on some items will be taken into consideration if they dont sell fast. Paypal accepted. Thanks
I have a set of rear brake calipers, at the moment i cant find one of the brackets but i know i have it. 75 + shipping
60K rearend with Richmond 373's. I had no wine whatsoever but a pin was loose and i broke my Posi. Gears and everything else is in perfect. 75 + shipping.
Rearend that i bought off a junkyard to replace the one above. Has the ABS plates and ring on axles. But one of the axles is bent and i believe the tube where the axle goes in is bent aswell. 342's and posi work good. If parts desired let me know. 110 + shipping
Rear rotors still have life in them 20 + shipping.
Old 07-31-2007, 02:59 AM
ROCNDAV's Avatar
Do you have #9 in the link below by any chance?
https://ls1tech.com/forums/parts-wanted/582549-rear-98-02-brake-parts-needed.html
Old 07-31-2007, 04:55 AM
james562's Avatar
pm on gears sent
Quick Reply: Rear End, Rotors, Calipers
