Bad ass 2003 Yamaha Banshee!
Bad *** 2003 Yamaha Banshee!
170135898361 is the auction number, check it out!
2003 Banshee, one of the cleanest, babied, and nicest running ones i've ever seen. You really have to ride this thing and see it in person! Looks so mean.
Motor is internally stock, never been opened up! roughly ~60-70hrs max ride time.
(new)Maier black race cut front plastic.
(new)Maier carbon fiber look rad cover and tank cover (riveted).
(new)Hetrick racing adjustable clutch lever and perch.
(new)Modquad billet thumb throttle lever.
(new)Pro Taper black SE, CR low bend handlebars.
Spider grips.
(new)YZ kill switch.
billet "hide a key".
YFZ450 front a-arms. custom billet spacers on the lower arms.
(new)2006 YFZ 450 take-off front shocks. (15 coil springs). 3-way adjustable.
FMF shock covers for all 3.
rear wheels flipped to widen/match the front width.
stock wheels and original tires with a good amount of tread.
Toomey Racing T5 pipes/stingers/silencers.
Pro Design Pro FLow billet air filter adapter with foam filter and K&N precharger. stock airbox modified so filter is an open element but still uses factory airbox supports. (no need to use filter oil)
deleted coolant overflow tank. overlfow hose routed down the front of the frame.
stock 26mm carbs with 340 main jets, 27.5 pilot jets, stock needle in the middle clip position.
runs on 40:1 premix of Yamalube 2R oil and 93 octane.
(new)kick start lever freshly rebuilt (to cure the common rattle issue).
parking brake lever and cable deleted, billet p-brake block off plate on rear caliper.
billet Pro Design "power shifter"
$3000 to any ls1tech member! Reserve is well under the BIN price.. Pics on the way!
(217) 416-0227
OR
Ebaird83@yahoo.com
OR
PM or reply!
Spider grips.
(217) 416-0227
OR
Ebaird83@yahoo.com
OR
PM or reply!
