5.3L s10 on a 2002' 5.7 tune and injectors??
I have an s10 that is a 5.3. Right now the computer is flashed for an 02 fbody and has the stock fbody 28Lb/hr injectors intake etc. I was going to get a dyno tune once it is up and running. But should the larger injectors and the IFR table for the pcm cause any troubles with the 5.3 until I can get it squared away enough to get the final tune done. I have a friend with hpt and we disabled the vats set everything for gears tires etc but left all of the engine and transmission tuning alone. Is there anything I should copy and paste to make it run for now for engine safety reasons? Thanks
