i have guys telling me not to run c16. need some experience here
i need to tune the truck without meth using pump gas and a vp fuel of some kind. localy i can get c16 and have always thought that was the best fuel out there.
the set up on race fuel is 408, afr heads, twin gts 70's, decent air to water intercooler. going to push it to 20psi or so and over 1000rwhp on a dynojet.
here are some quotes i am geting. is this the consensus? should i go with c12 even though it is just 108 octane?
""""don't run C16 in a turbo car with an intercooler, period.
you'll lose a shitload of power. Trust me, I've tried it a lot out here. You should be running something like C12 or 114 for your combo. The C16 requires super hot IAT's like blown454 says - it's meant specifically for roots-blown engines that run 200 degree F and higher intake air temps. And it slows them down too.
A lot of import "racers" and other people will try to tell you otherwise, but hours of dyno testing has shown me it's not meant for the kind of combo you are running. """"
There have been times where i have seen cars make less power on too high of octane. but with 20psi you may or may not need it. it really just depends on how good your w/a intercooler really is. If it does keep you IAT's low then i would stay with the 112 or 114 tops.
Any tuner that has any ability at all is going to make loads more power on C16 than pump gas in any turbocharged application....disagreeing with this one is out there with the urban myths that 'Speed Density tuning doesnt work if you live in a high altitude'.
If a tuning shop tells you either of those, the solution is simple....take your money and run far, far away
Any tuner that has any ability at all is going to make loads more power on C16 than pump gas.
Coal Mining Director
Property
Standard
Leaded
Supreme
Leaded
MO2X
HCR Plus
Maximal Leaded
More Information
More Information
More Information
More Information
More Information
Specific Gravity
0.728
0.715
0.717
0.739
0.708
Antiknock Index (R+M)/2
110
112
112
114
116
RON, Research Octane
115
114
115
118
118
MON, Motor Octane
105
110
109
110
114
Reid Vapor Pressure
5.6
6.3
9.8
6.0
5.9
Distillation, ºF
Initial Boiling Point
100
98
92
102
103
10% Evaporation
179
170
122
181
170
50% Evaporation
222
219
208
217
217
90% Evaporation
248
232
229
226
232
Final Boiling Point
369
257
251
245
257
Leaded
Yes
Yes
Yes
Yes
Yes
Color
Purple
Blue
Green
Orange
Red
Oxygen, Wt.%
0.0%
0.0%
2.7%
0.0%
0.0%
Dielectric Constant
-0.1
-0.7
6.9
0.6
-0.9
Standard
Leaded
Supreme
Leaded
MO2X
HCR Plus
Maximal Leaded
More Information
More Information
More Information
More Information
More Information
Specific Gravity
0.728
0.715
0.717
0.739
0.708
110
112
112
114
116
115
114
115
118
118
MON, Motor Octane
105
110
109
110
114
Reid Vapor Pressure
5.6
6.3
9.8
6.0
5.9
Distillation, ºF
100
98
92
102
103
10% Evaporation
179
170
122
181
170
50% Evaporation
222
219
208
217
217
90% Evaporation
248
232
229
226
232
Final Boiling Point
369
257
251
245
257
Leaded
Yes
Yes
Yes
Yes
Yes
Color
Purple
Blue
Green
Orange
Red
Oxygen, Wt.%
0.0%
0.0%
2.7%
0.0%
0.0%
Dielectric Constant
-0.1
-0.7
6.9
0.6
-0.9
Originally Posted by black98ws6ta
That right there answers your own question....you MAY NOT need c16 for the octane alone.....and it may make less power compared a lower octane......... BUT WITH LESS OF A SAFETY MARGIN.
I agree.....
Ive been running Torco latley and i run the 118 octain stuff..... might not need it over the 116 but id rather be safe then sorry....
KP would have some good insight on this since i know he runs less then c16..... if im not mistaken i believe he runs 110..... no meth either...
Kyle
C-16 is a good fuel, but form what i have heard, this new VP import race fuel is the nuts! think the octane is over 120! also they recon it will make 5% more power than any other nonoxygenatted fuel.
thanks Chris.
thanks Chris.
Originally Posted by Quik
i thought you already made 1011rwhp/1080rwtq?
it is a long story but i need to tune it with a vp fuel and make is as absolutly safe as i can.
most people i am talking to say it will be down on power with the c16 but i have a ton of turbo. wont i be able to toss an extra psi or so at it and be right where i was but probably still be safer because the c16 is kick *** stuff?
