Anyone running a S-trim?
Old 08-02-2007, 01:29 PM
ONEBADWS6's Avatar
Default Anyone running a S-trim?
Thinking of droping my comp down to 10-1 and bolting on a S-trim I have with a front mount intercooler. I'm affraid the blower is way to small for my 402. Opinions?
Old 08-02-2007, 10:48 PM
mitch98ss's Avatar
the s trim performs equal to the g trim go with the t or the ysi on the 402
Old 08-03-2007, 10:23 AM
ONEBADWS6's Avatar
The S-trim is MUCH bigger than a G trim. There has to be someone running one.
Old 08-03-2007, 10:45 AM
2001WS6Vert's Avatar
I ran a T on a 418. It made 13 lbs. with the aftercooler & 11 through the FMIC. I would expect a couple lbs. less with an S. Your combo sounds like it's pretty high flowing so I would expect even less, I know someone who has a T for sale.
Old 08-03-2007, 11:45 AM
ONEBADWS6's Avatar
I read from Vortech that the S is good for 20lbs of boost. If I don't run the S I will just buy a buddies spare YSI.
Old 08-03-2007, 01:12 PM
Got Me SOM's Avatar
If I find 2 grand laying around somewhere I wanna throw that T trim on mine
Old 08-03-2007, 02:52 PM
DeltaT's Avatar
The S-trim might be capable of 20# of boost on a 3 litre motor, but it maxes out around 680fwhp (according to Vortech). The most I could get out of mine on a 383 was 7.2# after the FMIC, but it put down 501rwhp through a big 4L80E tranny.
This weekend I am firing up the T-trim replacement!
Jim
Old 08-03-2007, 03:41 PM
Since your already in the 9's I would say you need at least a YSi.
Old 08-03-2007, 04:29 PM
ONEBADWS6's Avatar
Time to sell the S-trim.
Old 08-04-2007, 05:08 PM
GTOLarry's Avatar
I run an S-Trim but I only have a stock LS1 with cam. Seems like Ysi would be more up your alley. S is a 1000 cfm, T is 1200 cfm, Procharger D1-SC is 1400 cfm, seems like Ysi 1600 cfm or Procharger F1 would be a better match for you.
Old 08-04-2007, 08:53 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,226 Likes on 782 Posts
LS1Tech 10 Year
To go how fast B?
Old 08-05-2007, 04:00 PM
ONEBADWS6's Avatar
Well if I spray the car I think it's 8.70 capable. I think with the S-the car would go 9.4's on E85 with mufflers all day long. So I gues to get to the spray level it would need a YSI. Or a F2R!!!!
Old 08-05-2007, 04:10 PM
LS1Tech Co-Founder
LS1Tech 10 Year
For 8's you need a YSi, X, or F1_.
Old 08-05-2007, 05:50 PM
engineermike's Avatar
LJ was pulling right at 140 mph in the quarter in a heavy car using an S-trim several years back. He was only running about 12 psi, while slightly over-speeding the blower. Go here and click on "timeslips", then "9.94 at 139.1":
http://para.noid.org/~lj/
It was a 383.
Though. . . all I could get was 133 mph from my T-trim making 13 psi through an aftercooler on a 383...
Mike
Old 08-05-2007, 06:12 PM
LS1Tech Co-Founder
LS1Tech 10 Year
I would think you would need around 145 if your car was like 3200 raceweight? T-Trim is rated for 825hp, and YSi is rated for 1200hp. Thinking about it, a T-Trim would run 8's, YSi's have been going 8.4-8.6's in Renegade and Drag Radial Mustangs.
Old 08-05-2007, 06:54 PM
Yea, the S-trim is rated at 680 fwhp, but I'm sure Jeff was around 750. The T-trim is rated at 825 fwhp, but 925 fwhp has been proven on a dyno on a stout 402 SBC.
Old 08-06-2007, 09:15 AM
ONEBADWS6's Avatar
My raceweight is 3150 and the car makes 504rwhp on motor through my Th400 and 12 bolt. I'd lose 40-50hp by droping 4 points of compression but what would I get back max effert out of the S-trim? maybe 650rwhp?
Old 08-06-2007, 09:34 AM
LS1Tech Co-Founder
LS1Tech 10 Year
I think you would need at least a T-Trim or ProCharger equivalent, that S-Trim is too small for your engine.
Old 08-06-2007, 12:33 PM
I've heard of folks getting close to 600 rwhp from an S-trim through an auto. Not too sure about 650. . .
Old 08-06-2007, 12:49 PM
ONEBADWS6's Avatar
so it would be like adding a 100 shot to what I have now. Damn.
Quick Reply: Anyone running a S-trim?
