3 Hours For Spark Plug Change
Old 08-02-2007, 02:29 PM
ealucero1's Avatar
Default 3 Hours For Spark Plug Change
I HAVE A 2000 SS CAMARO THAT I RECENTLY PURCHASED. ON MY FIRST SPARK PLUG AND WIRE CHANGE IT TOOK ME ONLY 3 HOURS. NOT BAD CONSIDERING THE PLUGS AND WIRES ARE 83,000 MILES OLD, ORIGINAL. I'M SURE ALOT OF PEOPLE KNOW THE PROCEDURE BUT I THOUGHT I WOULD SHARE THE WEBSITE THAT HELPED ME TACKLE THIS HORRIBLE JOB. I FOUND IT AT WWW.INSTALLUNIVERSITY.COM. ITS AN ELEVEN PAGE PRINT OUT AND SAVED ME ALOT TIME AND HASSLE. I'M SURE I COULD DO IT AGAIN IN UNDER 2 HOURS NOW THAT I HAVE THE FIRST EXPERIANCE OUT OF THE WAY.
Old 08-02-2007, 02:47 PM
XpEdItIoUs's Avatar
Damn, did you make a sandwhich and take a nap while you where changing them? JK... good job, If you have aftermarket exhaust manifolds (headers) it makes it alot easier.
Old 08-02-2007, 02:50 PM
TheLS1Kid's Avatar
3 hours isn't too bad. You'll get faster as you do it more.
Good job.
Old 08-02-2007, 03:00 PM
ealucero1's Avatar
This Is The Only Car I Have Without Headers And I Can Definately See How They Will Help In The Plug Install. By The Way I Had To Take Several Phone Calls, Because I Was Working On My Car At My Business. Take Away The Phone Calls And It Would Have Taken Me Around 2 Hours.
Old 08-02-2007, 05:10 PM
5_02ls1's Avatar
doing race style headers makes it a 20 min job....3hrs aint to bad...you should try an lt1 plug change.....
Old 08-02-2007, 05:33 PM
Kalgorn's Avatar
It took me over 6 hours my first time over two days but I was really taking my time and paying attention to what I was doing. My buddy and I changed the plug on his '02 in 2.5 hours (and that includes removing the 5th bolt on the passenger coil pack). I thought that was pretty good considering we were switching off with one 3/8" ratchet. He has Pacesetters too with block-offs for EGR and AIR which kept getting in the way as well.
I figure 2 hours for my next plug change and I have AIR still hooked up.
Old 08-02-2007, 06:06 PM
Red99TA's Avatar
When I had a '94 Z28 back before I knew much about cars I went to a Firestone shop to get my plugs changed and the mechanic quoted like $200 and said he would "rather get kicked in the junk than change out a camaro's plug wires"! I then went and bought a Haynes manual and figured it out on my own. It probably took about 6 hours but well worth the learning experience. I can do my T/A now in about an hour maybe a little more.
Old 08-02-2007, 06:09 PM
andrew69_04's Avatar
LS1Tech 10 Year
wow....changing plugs shouldnt take more than 2 hours. These cars do suck though. When your done you have cuts and redd scratches all over your arms! but hey you did it yourself
Old 08-02-2007, 06:30 PM
FireSilverLullaby's Avatar
Yeah the last plug on the passenger side absolutley sucks. took me forever to get a socket on it.
Old 08-02-2007, 06:48 PM
5_02ls1's Avatar
Default damn...
2.5 on a header car....wow.....
Old 08-02-2007, 06:51 PM
ealucero1's Avatar
I Bought A "thru" Socket Set From Lowes And Used It As A Last Resort To Get The Fifth Coil Rail Bolt Out, 10 Seconds Later It Was Out. Kobalt Thru Sockets, Its A Small Set For Around $60 It Was Worth It For That Bolt Alone.
Old 08-02-2007, 07:12 PM
Yeah thats the bolt i couldnt get off so i just had to rotate the coil pack bracket as much as i could. this is probley what made it so hard for me.
Old 08-02-2007, 07:19 PM
rich Z's Avatar
The first time I change plugs on my ls1 I followed the instructions in installuniversity and it too me 6 hrs. The other two times it took me 1hr 45 mins since I left the coil packs alone and took the no.8 plug from below. Getting the wires off is the biggest pain. I need to change mine soon since I used NGK 55's.
Old 08-02-2007, 08:11 PM
ErikElvis's Avatar
First time was pretty easy with the header install. The second time I went in it was prob an hour with cleanin and regappin for the driver side. The passenger side takes half as long.
whoops. I mean the other way around.
Old 08-02-2007, 08:40 PM
Kalgorn's Avatar
Well it's not a race header so it still has the emissions provisions and they really just get in the way with the block-off plates. Had to shove my arm under the headers to get at least one of the passenger side plugs.
Plus, this was his first plug change on the car so I was letting him do most of the work. He's like me though. He likes to take his time as well.
Next time on my car, I will be rushing it because I'm much more comfortable with the change.
Old 08-02-2007, 11:29 PM
biga0206's Avatar
Just did mine today while I did the header change. I'm not looking forward to the next change but can't see it taking more then 45 mins.
Old 08-02-2007, 11:38 PM
thecorrectformula's Avatar
I did mine today too. Snapped two spark plugs off in the head and it still only took me about two hours.
Old 08-03-2007, 10:18 AM
XpEdItIoUs's Avatar
HA noobs, It takes me 40 min at the most no a days.
Old 08-03-2007, 10:28 AM
Guido1's Avatar
speaking of wires, does anyone recommend msd or taylor
Old 08-03-2007, 12:19 PM
chavez885's Avatar
YOUR CAPS LOCK WAS ON
