Trying to remove paint from LS6 springs...
Old 05-20-2003, 01:32 PM
Y2K2LS1's Avatar
Default Trying to remove paint from LS6 springs...
....What should I use to do it? They have a light coat of yellow on them, and I dont want the dealer to notice under the oil fill cap, so I want to make them look stock. Do you think paint thinner would work, I dont want to harm or soften the metal whatsoever!
Old 05-20-2003, 05:03 PM
equandt's Avatar
Default Re: Trying to remove paint from LS6 springs...
This stuff called Goo Gone may work check your local hardware store. Laquer thinner may work well too.
Old 05-20-2003, 05:08 PM
Cal
Cal's Avatar
There's a special paint-stripper spray you can get at some autoparts stores, it works a lot better than any solvents or thinners.
Old 05-20-2003, 06:11 PM
highgear's Avatar
Why do you want to remove the paint stripe?
GM LS6 springs are covered under warranty.
Old 05-20-2003, 09:49 PM
Zeta's Avatar
You think the dealer is going to see a spring? I have a hard time seeing more than the top of the rocker.
Once the oil changes color, I think it would be really hard to see the color. Paint thinner will probably cut the stuff off of the springs. I seem to remember that it being very fragile and a light pressure from a standard screwdriver would flake the coating.
Old 05-21-2003, 07:56 AM
robertbartsch's Avatar
springs do come in different colors so I would not worry about your dealer thinking you changed springs.... now if he can hear the cam lope you are in trouble...
