Western Members CA, AZ, NV, UT, CO, NM, HI
Will the radiator fit?
Old 08-04-2007, 11:24 AM
Nine7T/A's Avatar
Default Will the radiator fit?
Will a 2000 T/A radiator fit a 97 LT1 T/A? Thanks
Old 08-04-2007, 02:04 PM
Soul TKR's Avatar
i'd think so... but you'd be downgrading... the LT1 radiator is larger and better than the LS1 one...
Old 08-04-2007, 04:29 PM
z28poweredlt1's Avatar
It will BUT< the lt1 radiator has provisions for the oil cooler, and if your car has that (not all of them do, forgot the years) then it wont work because you'll have 2 oil cooler lines with no where to go. If you had a prob overheating before it would get worse with the LS1 radiator, it's made for an Allum engine so it's thinner, hence the reason why I and a lot of other board members use LT1 radiators on their LS cars.
Quick Reply: Will the radiator fit?
