how much power can be made with out of the box L92's on a 408?
Old 08-04-2007, 12:08 PM
94 guy's Avatar
Default how much power can be made with out of the box L92's on a 408?
i see guys making high 400's to 500 with cnc heads.
Old 08-04-2007, 12:20 PM
WKMCD's Avatar
This guy did an in depth before and after on stock vs CNC's L92's. Lots of good info here.
https://ls1tech.com/forums/generation-iv-internal-engine/662314-l92-dynojet-numbers-plus-plan-b-c-d-e-f.html
Old 08-06-2007, 12:10 AM
2c5s's Avatar
https://ls1tech.com/forums/showthread.php?t=662314
I heard that guy races people in parkling lot's.
Old 08-06-2007, 06:00 PM
SUTTERERMAN85's Avatar
i think 500rwhp can be done with stock L92 heads on a 408.
Old 08-06-2007, 06:42 PM
1bigcam's Avatar
i made 503 whp with a 416 and ported heads but i think my cam choise is holding me back
Old 08-06-2007, 06:50 PM
ace68's Avatar
what pistons on a 4.03 boar ?
Old 08-06-2007, 08:11 PM
94 guy's Avatar
bigcam list some motor details please?
Old 08-06-2007, 08:12 PM
94 guy's Avatar
4.03 bore
Old 08-06-2007, 08:16 PM
LS1TECH Sponsor
Bryan@LME's Avatar
LME is seeing 515 to 530 rwhp running stock L92's w/ dual spring upgrade. This is with both the 408" iron and 402" LS2. LME is using a Wiseco custom piston and ring combo w/ L92 valve pockets that are 5cc's. The piston also has a 4cc dome that matches the L92 chamber. This allows 11.5:1 with no milling of the heads. 11.75 to 12.0:1 is obtainable with minimal milling of the head.
Old 08-06-2007, 08:25 PM
trtturbo's Avatar
Dont know about stock L-92's, but we will have some numbers on ported L92's and a 408 very soon.
Cam is not giant for this; 24x's, .61x.
Planning on spraying 300
Old 08-06-2007, 08:32 PM
94 guy's Avatar
trtturbo, what's the part# on the heads?
Old 08-06-2007, 09:05 PM
LS1curious's Avatar
I have personally seen 430/390 through a 4l60e with a 3600 yank sst converter on a mustang dyno.
Old 08-06-2007, 09:21 PM
kcmags's Avatar
Not N/A..but I had a set with springs only make 776 @14 lbs. Ran out of blower @ 6200 rpm.
Old 08-06-2007, 09:28 PM
1bigcam's Avatar
mine is 11 to 1, 1-3/4 headers no cats dual 3 inch exhaust x pipe ,ported tb, livernoise stage 3 heads, electric water pump, cam is 248-262 637-647 on a 112. if they are getting 515-530 with stock heads i will be calling them wednesday thanks b/c i got something wrong. i did not pay 2100.00 for ported heads to get less power thens stock ones
Old 08-07-2007, 07:18 AM
trtturbo's Avatar
they are just stock L-92 heads from Scoggin Dickey that have been ported by Greg Good.
Old 08-08-2007, 06:57 AM
WizeAss's Avatar
If you where running better headers (i.e. 1 7/8) you likely would not need all that cam to make the same power. also most of the port work on those 367 or so cfm heads was done on the exhaust side. That is where the LS3/L92 heads really need work! And.... yeah, they will make more power thens stock ones.
Quick Reply: how much power can be made with out of the box L92's on a 408?
