what kind of cam should i put in my lt1 z28
Old 08-06-2007, 01:51 AM
94_formula_lt1's Avatar
Default what kind of cam should i put in my lt1 z28
im looking for a good cam and i have no idea where to start i was going to go with 1 like this Comp Cams "305" LT1 Camshaft, 220 / 230, .510 / .510 112 LSA, but i just aint sure i want a good sound and i need to keep it street driveable with possibly a dyno tune later on can any of you guys help me thanks alot
Old 08-06-2007, 09:32 AM
plaf713's Avatar
comp cams 503, do a search on it, you'll find more than enough information on the cam, very streetable, the best cam for stock heads.
Old 08-06-2007, 09:39 AM
JoeliusZ28's Avatar
x2 on the 503. its what im going to get.
Old 08-06-2007, 10:02 AM
-PEPE-'s Avatar
Custom Grind for your application, have someone like Allan Futral spec it out for example and Cam Motions do the grind. Several sponsors on here that can build an awesome custom grind for your goals which should be the forefront of why you want a cam, 1/4 ET, better street performance, drag or everyday driver, little more sound or whatever floats your canoe.
