Predator tune for a 99+ gm truck
does anyone that can change a setting in the pcm using the predator? I need to enable the aux fans on a 99+ gm truck pcm and set them to come on at 178degrees. Can one do this through the predator or no?
thanks,
Lar
thanks,
Lar
Tech Fanatic
Re: Predator tune for a 99+ gm truck
As far as I know YES you can. There should be a setting under the "modify parameters/settings" section of the Predator. From there you should be able to access the fan settings.
I might need to look again. I saw the setting but it said that it was not installed. I might have been in the wrong area to enable it.
Lar
Lar
Sorry ArticGMC, It's a damn shame but the pcm's in the trucks don't have the fan option turned on. Now maybe someone could hack into it and enable it for us.
Tech Fanatic
That sucks, I dont have electric fans so I havent actually TRIED to enable the fans. I am POSITIVE that if you contact Diablosport or the place you purchased your predator that custom downloadable tune would be available to enable cooling fans.
