bleeding hyd. system
Old 08-07-2007, 06:03 PM
styoung's Avatar
Default bleeding hyd. system
i know this has been covered many times but the search is down and i need piece of mind. i just got done beeling my hyd. system and i want to make sure i did it right. when i bled the system i opened the bleeder and had someone push the pedal to the floor and hold it. i than closed the bleeder and repeated. now the pedal seemes ok but semi soft. it shifts better than before i just want to make sure i did it right. thanks.
ps ive got a cartek clutch and there slave.
Old 08-07-2007, 07:25 PM
Screamin_Z's Avatar
did u close it before they let off the pedal? how many times did u bleed it?
Old 08-07-2007, 07:32 PM
styoung's Avatar
yes and i did it until the fluid was clear. i put like a pint through the system.
Old 08-07-2007, 07:45 PM
Screamin_Z's Avatar
sounds like u did it right, being softer I wouldn't complain one bit as long as it's working fine.
Old 08-07-2007, 07:59 PM
styoung's Avatar
thanks man.
Old 08-07-2007, 09:04 PM
Screamin_Z's Avatar
with an aftermarket PP and clutch softer means more like factory. even tho my pedal feel wasn't bad at all it was stiffer after the spec 3 swap. I'm putting a Ram street twin in this weekend so I'm looking for more of a factory feel but handle everything I throw at it.
Old 08-07-2007, 09:15 PM
styoung's Avatar
so far i love my carteck clutch, very streetable and grabs hard.
