Car starts, wont run...
Ive had this problem for quite some time now and since Ive been deployed I havent had much time to deal with it.
The actual problem is the car will start run for about 2-3 seconds and then shut back off. It starts up fine and runs good for the couple of seconds that it does run, but thats it. Ive replaced a BCM, got the key checked (personally I dont believe its a passkey/VATS issue but Im open to anything).
Here are the codes its throwing:
C0050 - RR Wheel Speed Circuit Malfunction (Current)
B1001 - Option Configuration Error (History) (Immature)
C0121 - Valve Relay Circuit Malfunction (History)
U1000 - Class 2 Communication Malfunction (History) (Immature)
U1301 - Class 2 Short to Battery (History) (Immature)
U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
U1040 - Loss of Class 2 Communications with ABS (History) (Immature)
U1096 - Loss of Communications with IPC (History) (Immature)
Im really at wits end with this issue and thrown too much money at it already. Ive been told its a ground but all the grounds Ive been told to check seem to be in working order.
If you have any advice what so ever, please post it up. Nothing would be more satisfying than getting this car running so I can start buying parts for it while Im back in Iraq.
Thanks guys!
Thanks guys!
ifit was vats it would flashthe security . i persoanlly never have ran into these error codes and it does sound electrical . it could be a ground or somehting grounding out somewhere .
if you have not already try pulling the fuses and seeing if you luck up . also try to disconnect the regular pcm and make sure it is on correctly . finally if none of this workstry to post this in the PCM Diagnostics & Tuning or the stereo and electronics as somewhere there may have ran across this .
good luck and welcome home
