LS1 with 5.3L heads
LS1 with 5.3L heads
If using a stock LS1 block with an LS6 cam and stock 5.3L heads, will the pushrods have to be the shorter aftermarket ones or will the stock ones work?
thanks
thanks
of coarse you would. But I would upgrade to at least a set of P/P LS6 heads & possibly at least a 224 cam or you might end up doin it all again later if it doesn't pick up as much as your hoping for.
And if you do heads don't forget to at least upgrade to LS7 lifters.
