Will a LC1 send a WB signal without being connected to a laptop???
Old 08-09-2007, 11:24 AM
teddyca's Avatar
Default Will a LC1 send a WB signal without being connected to a laptop???
I am sure it will but wanted to check. I have it hooked up to a NB and like I was told it is completely worthless. I am going to order a WB gauge and go from there. I was wondering if it will read rel time A/F?
Old 08-09-2007, 03:58 PM
2002_Z28_Six_Speed's Avatar
Short answer, yes. It will read out real time AFR.
If you have a voltmeter and like math you could watch the real time AFR.
I would not order the Innovate WB gauge, though. It is 250.00.
Order a decent 0-5V WB gauge. You will have to connect a laptop to the LC1 and program the analog output to get this to work.
Old 08-09-2007, 04:51 PM
teddyca's Avatar
I did connect my NB gayge and it makes no sense at all. I was told it I connected it to the low voltage signal it would be decent but no luck. Maybe I need to connect my laptop and configure it first?
Old 08-09-2007, 07:23 PM
What voltage range is the gauge rated for? The LC1 is only programed to put out about 1 volt from the factory. Least my LM1 was set up like that.
You will probably have to hook it up to the PC to make it compatible with the gauge.
