Fidanza Ring gear loose
Old 08-10-2007, 08:40 PM
Supraman's Avatar
Default Fidanza Flywheel problems
I took out my trans today and removed my clutch a spec stage 3. It seems that the ring gear on my Fidanza aluminum flywheel is loose. Does this flywheel have a floating ring gear? The ring gear slides 1/16 of an inch back and forth. Has anyone also had this problem? Is the ring gear a replacement part like the steel insert? Their website says that the ring gear is heated and put on the flywheel to secure it.
Any ideas ?
Old 08-11-2007, 05:39 PM
Supraman's Avatar
to the top
Old 08-15-2007, 07:03 PM
Supraman's Avatar
Anyone
