408 with 60lb injectors tune
Old 08-11-2007, 03:56 PM
STALL UP's Avatar
Default 408 with 60lb injectors tune
does anyone have a hptuners tune for a 408 with 60lb injectors that would help me break in my engine before I take it to get professionaly tuned. the car is an 02 Z28 with a 408 iron block d1sc 60lb injectors mid 230 to 240 cam and patriot stage III ls6 heads ls6 intake full bolt-ons I still have about 6-8 weeks untill car is done so I have some time to play with. thanks
Old 08-12-2007, 01:10 AM
ZL1Killa's Avatar
i can get your injectors with the right IFR table and such...thats all i know
Old 08-12-2007, 01:23 PM
STALL UP's Avatar
thanks for your help, I will let you know if I need you to help me. thanks phill
Old 08-15-2007, 12:59 AM
STALL UP's Avatar
anyone else willing to help me out
Old 08-15-2007, 01:14 AM
firehawk123's Avatar
can you send me your HPtuner file i will make it run but you have to do custom tune for it.are you using maf or SD on it.
Old 08-15-2007, 11:27 AM
STALL UP's Avatar
I would really apreciate it I am using the maf. the current tune is from the stock 346 with 42 lb injectors. My brother has HPTuners with wideband so I can put the wideband on it to check and adjust the fuel. I just dont know what to change from the old setup to the new setup so I can drive the car and get the engine broke in before I take it to a professional tuner. Thanks phill
