breaking point of stock input/ output shaft?
It should be fine with your set up. When we did my clutch the input shaft was almost non existent, we had to order a new one. Just take a good look at your stocker and see what it looks like now.
6speed inc has some if need be.
I have failed a 27 spline f-body output at 520whp. I went 10.11 at 134 at the time of the failures. I did not break the output, but I did twist it .100. I also had 200 passes launching on 28/10.5. I have seen the input twist at 700whp, but that was with alot of passes on it. It is reasonable to say that a t56 is capible of lots of 10 sec passes. The viper output adds piece of mind. I have not seen a viper ouput fail at 1400whp.
