y-pipe banging?
Old 08-13-2007, 11:32 AM
2KnbmTA's Avatar
Default y-pipe banging?
just put my LT's on this weekend, and the y-pipe likes to bang a lot. a buddy of mine took his to a shop and they put this thing on the floorboard that looks like its padded on one side and adhesive on the other. ive never seen header wrap or anything so i wouldnt know if thats what it was. anyone know of anything that is carried at o'reillys or lowes that sounds similar?
Old 08-13-2007, 01:28 PM
1FSTLS1's Avatar
Poly motor mounts!!!
Old 08-13-2007, 02:33 PM
SLP4CamaroSS's Avatar
im stoped banging after i put a new energy susp transmission mount on
Old 08-13-2007, 03:44 PM
95 Z28's Avatar
I was gonna ask....I bet he didn't to poly mounts. You could try that Mufflex hanger too...i think Thunder sells it.
Old 08-13-2007, 03:58 PM
Marz's Avatar
use a valve spring or a drum brake spring and put it in between your body and y-pipe under driver seat either tack weld it or use tie wire to hold it in place and you should have no more problems enjoy
Old 08-13-2007, 04:57 PM
Restricted User
socmguy's Avatar
you can buy the Y pipe hanger from ws6store that's supposed to stop it ($40) or go with what the other guys are using. Is it causing your knock sensors to react?
Old 08-13-2007, 09:48 PM
Joker98's Avatar
I bought the Mufflex bump stop hanger and its junk!!! I used a rubber exhaust hanger(the ones that are like an inch thick) and no more banging!! I was worried about it melting but 2 months later and it's still workin mint
Old 08-14-2007, 09:29 PM
Redlinez's Avatar
This thing is junk http://www.thunderracing.com/?action...s528_large.jpg Sure sounded good to me. Got any pics or links to what you bought?
