stall question
With a very efficient converter with a low STR, you will even pick up rwhp vs. the stocker. So the benefit is two-fold. Your dyno chart will read higher in every gear, plus, you'll drop less rpm between shifts, keeping the engine at a higher torque point.
A very huge converter can still slow you from a roll, but still drop ET, since you'll be off the line much quicker.
The old converter was a TCI 3500...I just put a new motor in the car along with the stock converter..Cant beat on it so i was just wondering if its gonna feel slower without the stall
Originally Posted by performabuilt
yes it will tend to feel slower after you have gotten used to the stall
