New to LS1TECH
New to LS1TECH
Just a quick hello to everyone here. I bought my 99 SS in Aug. 2000 with only 3200 kms on the odometer. I left it stock for quite awhile until the last few years. Unfortunately, its currently all apart for installs. Here is a list of what is installed or under way...
Patriot Stage 2 Heads
ARP Studs
Jesel 1.85 shaft mount rockers
Comp Cam
Spec Stage 3 Clutch and Billet Steel Flywheel
Wilwood SL-6 front and 4 piston brakes and slotted/drilled rotors w/stainless lines.
3" true duals w/chambered mufflers
Meziere Electric Water Pump
SLP Double Rollr Timing Chain, MAF, LID, Off-Road LTs, Line Lock
UMI Sub-Frames, LCAs, Panhard, and Torque Arm
LS6 intake
Dynojet Wideband
36lb/hr Injectors
MTI ported TB
Hotchkis Polished Strut Brace
MSD wires and Coils
Carbon Fibre Driveshaft
Torsen T2R 3.73s
Tuning by CK w/HP tuners
ZL1 grille
C6 Z06 18s Michelin Pilot Sport PS2 295 rear/265 fronts
315 Nitto DRs on 17s
Still researching shocks. May have left a couple things out.
Also have an '07 CBR600RR and an '07 Cobalt SS LSJ. Both are stock, but not for long!
ARP Studs
Comp Cam
LS6 intake
Dynojet Wideband
36lb/hr Injectors
MTI ported TB
MSD wires and Coils
Torsen T2R 3.73s
ZL1 grille
