Just finished throttle body install but have a question.
I just finished installing a slp lid and ported throttle body on my 2002 Camaro. After the install I noticed the throttle cable is kinda loose and not very tight. Is this normal or is there a way I can tighten it?
Restricted User
do you have the proper cam on there for your car's model year? they were bigger from '00-'02. If you have that year and put on a TB w/ the cam from a 98 99 that could be your culprit. The CC cable also can be adjusted by pinching in the plastic clips that attach to the throttle cam, pulling out the slack and then pushing them back in.
