need help wit head/cam pkg
Old 08-17-2007, 06:45 PM
aDaM Ws6's Avatar
Default need help wit head/cam pkg
Ok I have a 02 ws6 with Full bolt ons and in a couple weeks i plan on getting this Heads/Cam setup. This is also my dd but fuel economy not a prob.
Afr 205 62cc
Cometic .040 head gasket (duno if i should go .045?)
Comp PRC dual spring kit
Hardened Chromoly Pushrods
Yella Terra LS1/6 Non-Adjustable Rocker Set (duno if i should go with these or harlands)
Texas Speed Torquer V.3 231/234 .643"/.598" 111 LSA
GM LS2 Timing Set
TSP Ported LS6 Oil Pump (duno if i need new one, stock is at 55k miles)
Am I going to run into any problems?
Any help will be appreciated, Thanks.
Old 08-17-2007, 06:53 PM
mr2guru's Avatar
problems? other than the valves hitting the pistons, no... no problems....
Old 08-17-2007, 07:14 PM
JPH
JPH's Avatar
too funny.
