Whats the power range of this cam ?
Old 08-18-2007, 12:10 PM
Randy WS6's Avatar
Default Whats the power range of this cam ?
I have a Crane 250/266-632/632-112+4 ,whats the power range of this cam shaft, Its going in my LS2 418cid. and i have Dart Pro heads 255cc chambers 2.100 int & 1.60 ext. valves and i have adjustable timing chain ,do i need or should i add or subtract timing with the timing gear
Old 08-18-2007, 01:17 PM
JPH
JPH's Avatar
i would say 4500-7800rpm. i'm sorry i don't know off of the top of my head but i should know, because i have that cam card at home too for this profile. degree cam first, see where it comes in at, then make an adjustment to timing set if needed. but install at 0* for right now (straight up).
Old 08-18-2007, 01:31 PM
Randy WS6's Avatar
I found this>>> http://www.cranecams.com/?show=brows...tType=camshaft is there any way i can get any more rpm out of this cam plus ill be running nitrous
Old 08-18-2007, 01:44 PM
JPH
JPH's Avatar
trust me it will go higher, but retard it (-4*) for now if you want more rpm from it. how much spray are you using and whose valve springs are you running.
Old 08-18-2007, 08:08 PM
N4cer's Avatar
I must've missed it. What intake are you running? That will also determine where you need to spin it to.
Old 08-18-2007, 10:56 PM
Randy WS6's Avatar
Ported Fast intake 90mm . Holley 90mm TB.
Old 08-19-2007, 10:48 AM
JPH
JPH's Avatar
hey the cam in your signature looks alot better for your set up, instead of the one we have been talking about. IMO.
