5.3 heads on a 6.0 Truck block
This is kind of a follow up to another thread I started, but this is way more succint.
I have a set of ported/re-valved 5.3 heads. Can I bolt them onto a stock 6.0 Iron truck block without having major compression issues?
Cam will be in the 224-234 at .050 range
If not, will it be better to port a set of 5.7 LS1 heads or the stock Aluminum 6.0 heads (The # on the truck heads, passenger side next to the valve cover is 317 if that helps)
Thanks
Thanks
