opinion
opinion
looking at the jeg's version of the prostar vs. the real prostar. Only difference i can tell is the center cap..one says jegs, other says weld racing. Is there any other difference that im missing?
JAce
JAce
The jegs is heavier and last I heard they don't make the correct backspacing for the rears, but you can use the summit ones for the rear as they don't make the correct backspacing for the front (They look identical). You don't have to use a spacer on the fronts with the jeg stars and you DO with the welds.
