Clutch pedal doesn't come back up all the way... here's a new one for you...
Just finished installing a new Spec 3+ , flywheel and slave. I had to bleed the system and while I was pumping the pedal, something felt like it gave and the pedal went down about 1". I continued the bleeding but the pedal would not come back up all the way. Upon examining the rod coming from the pedal assembly going into the master, I noticed that when I pulled the pedal up, the outer top part was coming back up while the lower part was staying there. What in fact happened was that the 2 crimped areas on the outer part of the rod had givin away and the inner part was going in deeper. It turns out that those 2 crimps in the outer part of the rod are all that holds the threaded area on the inner part. All I had to do was put a spacer inside the outer part and the problem was fixed. This would be another something to look at when you have the problem of the pedal sticking 1/2 way. I thought it was air in the system and I bled it for 1 hour before I realized that the rod was weird. Pedal now feels great .
Originally Posted by SPEC-01
Nice find Steve...so do you have any pics of this. It would be nice to add this as a sticky for those that have similar issues in the future.
