can someone PLEASE help me (LT1 in phoenix)
seriously, this is pissing me off so much... i have a list of **** thats causing problems.. i dont know how to adjust my rockers, but even if i did my guideplates wont seat on the studs. since i cant get the rockers done, i cant put on the intake. i also cant get on the crank hub. is there ANYONE who has experience with this stuff who could help me out?
ive been doing fine so far, but its like all of this **** is hitting me all at once..
My guideplates are mounted under the studs.
I know there is a thread explaing how to adjust rockers, don't think it is this forum I read it on.
But if you are putting the guide plates on top that could be the problem.
As far as adjusting the rockers (assuming your pushrods are the correct length) you crank em down until you can just turn the push rod with you fingers and then a half a turn more and lock em down. You need to make sure that the lifter is on the base circle of each one you do when you do it.
If you are using the starter to turn the crank diconnect the igintion and fuel pump when you do.
Hope that helps some.
yeah, i figured out the studs.. and ill figure out the rockers, thanks for the help..
but i swear to god, i would pay someone to put this ******* crank hub on.
