Hitting the rev limiter @ aprox 4500-4800
1 Post
Not sure whats going on here. Heres what is happening, I will have the car in drive and from a dead stop it will pull till 4500-4800 and sound like its hitting the rev limiter, then it will shift into 2nd gear.
First thing, i think thats way too low even if its the factory limiter, second, why would it be doing it in automatic mode, i can see if i held first gear. Any ideas?
sounds like one of the two problems I ran into. I would get a slight studder around 2500 and then by 4grand it was like the car hit a brickwall on the acceleration. It progressively got worse to where I could only go up to 2grand and then had to shift.
My opti and coil went bad. that solved abotu 99% of the problem. The other 1% was the coil and ICM getting too hot becuase they were sitting on the head in the stock location but didnt have the AIR Bracket inbetween them. So I have since remote mounted both of them and the problem is gone.
for cheapness sake try just remote installing your ICM and Coil Pack and see if it fixes any.
1 Post
Newbie question, what and where is my ICM? Where did you relocate yours too? Any parts I need to buy to do this?
