install clear corner?
How do u install clear corners for 02 Camaro?
I tried searching but nothing came up. thanks
remove your headlights (you have to undo one bolt on each, then twist them and turn them till they come out)
then the clears pretty much drop right in if i remember correctly. there may have been one other bolt in the way. i think it was a bolt or nut holding on the bumper cover. its really easy though.
i just installed mine and now i have to take them out b/c one is leaking and filled with water today when it rained ..i hate ebay ****
has anyone else has this problem...and also the main running light bulb is melting the bottom of the houseing....this is pissing me off majorly
