airbox rubbing against hood?
Old 08-25-2007, 08:55 PM
2KnbmTA's Avatar
Default airbox rubbing against hood?
well ever since i bought my car, the airbox has been scraping on the hood. when i bought it it had a whisper lid i think (the ugly one that says ls1) but i just got a carbon fiber one, and i dont want it turning to **** like the other one. i mean the other one was worn down pretty bad. any good fix that you guys know of?
also, my blinkers are really really slow, and blow out more often than normal, anyone else had this problem?
Old 08-25-2007, 08:58 PM
02LS1WS6's Avatar
I'd like to hear some feedback on this one also...my slp lid that I installed not too long ago rubs my hood a bit on my WS6. I'll definitely be checking back on this post to see what everyone has to offer. So yep...my slp lid rubs on mine also
Old 08-25-2007, 09:43 PM
7th Darkness's Avatar
Yeah I have an SLP lid and it does the same.
Old 08-25-2007, 11:08 PM
02LS1WS6's Avatar
any way to fix this problem or is it just one of those things that you have to live with? just curious...
Old 08-25-2007, 11:38 PM
bayer-z28's Avatar
So far I've seen two cars that have the lid rubbing against the hood.. Mine does it too. I just ground a bit off the fiberglass on the underside of the hood w/ a file.
I have an SLP lid and my buddy has a CF lid.
Old 08-25-2007, 11:58 PM
01Z28M6's Avatar
I don't know the setup for the trans am but the slp lid on my carmaro rubbed my aftermarket hood. I used a heat gun to dent the lid down a little at a time.
Old 08-26-2007, 09:33 AM
2KnbmTA's Avatar
I was wondering if i could cut or grind something down on the piece that the lid clips to. also, my lid doesnt even fit good. one side of it fits over and the other doesnt.
Old 08-26-2007, 01:41 PM
02LS1WS6's Avatar
that sounds like a good idea to me...never though of that one...hmm...might have to try that sometime...can you visually tell that the lid has been heated???
Old 08-26-2007, 07:23 PM
01Z28M6's Avatar
No, I can't see that it has changed in shape and I think I need to try heating and forming it again. I think it is either not touching the hood now or reduced contact. It's hard to tell since the marks are already on the underside of the hood from before.
Old 08-27-2007, 05:39 PM
02LS1WS6's Avatar
yeah i'm gonna go outside now and take a look at mine...i think i'll try the heat gun approach and see how that goes...i just really wish it was somethin i could do to adjust it and make it sit lower somehow...
Old 08-27-2007, 06:04 PM
Quickin's Avatar
Mine did this and I found that the two rubber stops that screw in at the two front corners of the hood, underneath near the headlights inside the engine bay....were worn out and slipping downward. Get new ones and screw tham in, I think they were $10.00 each at the dealer.
Fixed the problem.
Old 08-28-2007, 10:03 AM
5301113's Avatar
My rubs a little bit. but not enough to hurt anything. i just live with it
Old 08-28-2007, 10:41 PM
frisky2101's Avatar
mine did the same thing once i put the SLP lid on, bought a new superhawk hood and now have no issues....
also you find out anything about the blinker lights, mine does the same thing, blinks a little slow and seems like i am always replacing one of them every six months
Old 08-29-2007, 12:54 AM
BayAreaSS's Avatar
My slp lid has rubbed my SS hood for a long time. I'll check those rubber stops and try to adjust them
Old 08-29-2007, 09:27 PM
02LS1WS6's Avatar
bayareass...pm me and let me know how that works for you if you don't mind please...thanks
