Keep getting 0121 and 0122 codes
Old 08-26-2007, 11:36 AM
99blancoSS's Avatar
Default Keep getting 0121 and 0122 codes
THis is driving me slightly nuts. Keep f%^& getting these codes 0121 and 0122.. ?????
Old 08-26-2007, 12:53 PM
Frost's Avatar
They are both codes meant to tell you that your TPS is bad... You say you "keep" getting these so I assume you have replaced the TPS and verified the wiring back to the PCM?
Old 08-26-2007, 01:11 PM
99blancoSS's Avatar
yep, replaced it. wires look good
Old 08-26-2007, 01:44 PM
Frost's Avatar
With the harness unplugged and the key on, what do you read on the + side that feeds the sensor from the PCM?
Old 09-01-2007, 07:05 PM
99blancoSS's Avatar
Ok, checked it all out with my multi meter not a digital readout and what I see is this: +4.4 at the + side of the plug then, when it's pluged in and I measure the output the max is 4.0 at WOT. You can see it climb as you move the throttle.
Old 09-03-2007, 07:36 PM
tdogg5.3's Avatar
I've had the same problem for 2 years with my truck. they say its be caused by my big cam and big stall. there was a post about it where someone changed a variable in ls1 edit and it fixed it. i'm bought edit last week so i will try this. do a search for thread for more info. its real annoying i know.
Old 09-03-2007, 07:43 PM
99blancoSS's Avatar
I've got EFILive coming as well so it's going to get taken care of.. lol
