Interior Swap
Interior Swap
Just Wondering If Anyone Has Done A Dash Swap To The Newer Style?? If So Will Everything Work Fine Or Will I Have Problems Such As Rpm Mph Odomitor And How Bout The A/c Vents Will Everything Work Fine??
i am gathering parts for this swap at this time.
you have to use a cluster from a 97 5.7,97-02 dash,the a/c duct behind the dash that sits against the fire wall 97-02,your fog light switch wires have to be moved to the center dash bezel,the trunk switch needs to be swapped to the drivers side kick panel above the knees(personally i like it in the glove box so mine will stay)the other hatch switch above the knee will make a great purge button!thats as far as i have gotten
