TH400 & Electric Shifter Setups
8 second club
Before I switched to a glide I had a B&M Pro Ratchet with electric shifter, it was a reverse pattern th400 with a brake. It worked pretty good after I dropped the pan and bend the detent bracket so it took less pressure to change gears. Before that it would not always make the shift correctly. Only one I've ever used on a turbo, so I can't comment on any other kind.
