Biggest lift with a hydraulic cam?
What is the most lift one can get with a hydraulic cam assuming the best valvetrain parts are used such as morel lifters. Whats the most duration? What limits this factors, is it the lifter not being able to hold the oil cushion or what not after a certain lift/duration? I tried a search and found some good info but no exact answers. Any help would be greatly appreciated.
LS1 Tech Administrator
Moved from Advanced Tech section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
I belive the morels are limited to .675 (seen that in some product descriptions, maybe cstraub can comment more on that). Two of the biggest limiting factors are spring preasures and RPM. How much? I cant say, that kinda tech is above my head.
89 gta, good question, i didnt think of that but it definitely has alot to do with it
DONAIMIAN- I did not know the morels were rated that high if so thats awesome!
My LSK/XER cam has .644 intake lift with stock lifters, Comp Pushrods, Patriot Xtreme Dual valve spring kit. The duration is only 227/228. The cam is from Thunder Racing, it was checked by them on a cam doctor. Duration will be limited by PTV clearance.
OWN3D BY MY PROF!
Comp LSK lobes have some pretty crazy ramp rates and lift. I have a chart of them at home that I'll look up when I get there.
EDIT: Comp LSK lobes go up to 264 duration and a .663 lift. I know you can have LSx cams ground with big block lobes though.
My cam doctored stick uses LSK lobes... .227/235 .645/.650 lift. I'm using Caddy lifters (although if I were to do it over I'd probably choose the latest Crane revision if they were compatible), Crane 3/8" pushrods, and PRC Platinum springs. Oh, and I've got valve reliefs in my pistons.
