Difference in valve covers?
Old 08-30-2007, 05:06 PM
SpdFrk1990's Avatar
Default Difference in valve covers?
I was looking at buying some used valve covers to paint and just block off all the ports and run a breather to delete the pcv. I seen some lsx ones with no pcv hoses except the one port on the back of the pass vc. Is the baffling any different underneath cause I did not really see any on these? They are off a newer corvette do the coil pack brackets bolt up the same also?
