traction control? On but off at the same time?
I dont have a TC switch in the car, however there is a toggle switch in the car, that is aftermarket. It is broke, needs to be saudered *sp is way off* back. I cannot burn out at the track, my rear makes noise and my car vibrates, but on the street I can light up 1st and 2nd gear, in a power break, going into 2nd gear my car bogs and will not burn 2nd. Wat is up with this?
if you had traction control, for 1 you would have a switch.
for 2, if you tried to do a burn out, the pedal would get hard and push back agaisnt you, im pretty sure you wouldnt keep pressing down trying to do a burn out if its fighting you.....
((((((Administrator))))))
Originally Posted by 94_9C1
...I cannot burn out at the track, my rear makes noise and my car vibrates, but on the street I can light up 1st and 2nd gear, in a power break, going into 2nd gear my car bogs and will not burn 2nd. Wat is up with this?
Your car is not a TC car.
Peace,
Craig.
Originally Posted by djsanchez2
Just look for the T/C Silenoid under the hood. Jeez. No Noid not T/C. Do you have one or two cables going to your TB? 1= no T/C, 2= T/C Easy Peezy
Yup you caught me i knew the T/C one had one more cable. So it's two and three. (but yes the non-T/C one has two cable to the TB.) Sorry bout that mix up. Was right bout the Noid though.
