Can you take a tune from a 93 and use it to put it into a 94's ecm?
I have a tune for a 93 that works real well for a specific combo. A friend is doing the same combo, yet in a 94. Can you take the file, and put the table over into the 94 , like using TunerCat or something, so we can flash the ECM in the 94? Instead of spending the money, it would be nice to use as much data within the 93s tune/bin, and then flash the 94, which we should be able to find here in HI.
I know the 94 is MAF, and a Flash ECM, but if we were able to flash it, we would like to use this tune to get things going.
My knowledge of LT1s == 0.5 outta 10
but... from what I think I know... 93s were the last chip based vehicles... 94 used an eprom
also 93s were speed density and 94s used a MAF.....
You could copy similar tables over .. but I would suggest having a new tune instead of copying an improper tune......)
