cam swap help!!
Old 09-01-2007, 05:32 PM
DSRCAM's Avatar
Default cam swap help!!
ok im doing a cam install in about a week or so and i was wondering if anyone know what size is the harmonic balancer so i can use a deep pack socket to get it out.. is that the fasted/easiest way to take it off and also to put it back on thanks in advance..
Old 09-01-2007, 06:23 PM
z28ss4me's Avatar
24mm and an impact wrench didn't work for me needed to a breaker bar to get it free. Good luck with the a4. If the impact wrench doesn't work, you'll need to lock the flywheel. There a tool for it, but I don't know where it is.
ls1howto.com tells how to install.
Old 09-01-2007, 06:26 PM
DSRCAM's Avatar
so u recommend just buying the flywheel locking tool...
Old 09-01-2007, 06:27 PM
fatdave's Avatar
yea like he said its 24mm if you cant get the tool to lock the engine in place you could remove the starter and use a good sized and strong flat tip screw driver or prybar to hold the flywheel still.
Old 09-01-2007, 06:33 PM
DSRCAM's Avatar
thanks guys i buy the locking tool but just in case that dont work ill do what u guys recommened!
