rear main seal, has to be broken in?
put a new rear main seal in about a month ago, everything was perfect until i went on a 600mile trip. then it started leaking oil from the rear main seal
was i suppose to drive it around for short distances or something for a little bit?
LS1 Tech Veteran
No. I'd say that you got the lip of the seal folded over. There are about three special installation tools (Kent-Moore and W2W are two) on the market to install it without folding the seal back over. In lieu of that, I would recommend taking something like a thin piece of plastic and carefully working the seal around the rear crank hub.
Steve
Steve
Check it out before you go tearing into the seal again...just my .02
