exactly what height to tap for oil return
Old 09-03-2007, 05:32 PM
383ls1blazer's Avatar
Default exactly what height to tap for oil return
hey whats up guys im getting ready to put my motor all back together after having my motor forged by lawless engines. i have to do a few things though before doing that and one of them is tapping for and oil return line from the turbo. i searched and found alot of info but no one ever mention exactlty what height to tap it at on the oil pan. I want to keep it a pumpless system (less crap in the engine bay) so i need to tap above the oil level.
Old 09-04-2007, 03:23 AM
SStolen's Avatar
Here are some pics from the APS TT kit:
Attached Thumbnails exactly what height to tap for oil return-lhs.jpg   exactly what height to tap for oil return-rhs.jpg
Old 09-04-2007, 07:57 AM
slow95z's Avatar
what about the pressure line, where would you install that exactly?
Old 09-04-2007, 02:35 PM
hey thanks man that is above the oil level correct?
Old 09-04-2007, 02:45 PM
SStolen's Avatar
You mean the oil feed line??? You tap the part that is bolted on next to your oil filter. Usually a 1/8th NPT (national pipe thread). You can just rent a tap and die set from autozone if you don't have one or want to buy a kit.
Old 09-04-2007, 02:46 PM
SStolen's Avatar
Apparently. How much higher could you really go? You think the oil pan is completely full of oil? lol.
Old 09-04-2007, 02:49 PM
black98ws6ta's Avatar
In addition to tapping it for the fitting to 3an/4an you will need to drill a hole in the bottom in order for oil to flow through it.
Old 09-04-2007, 03:00 PM
to tell u the truth i have no idea lol id assume it would be most the way full i guess once the engine is running it would go down a bit
Quick Reply: exactly what height to tap for oil return
