spark plug wire touching header.HELP
Old 09-03-2007, 07:41 PM
2fastWS6's Avatar
Default spark plug wire touching header.HELP
just got done putting my xs headers on today and everything went fine up till reinstalling of the factory plug wires.The #2 (passenger side front) wire rubber is up against the header tube.The wire started to melt on the header tube when I started the engine.HELP
Old 09-03-2007, 07:49 PM
2_wacko's Avatar
Get some MSD wires with the boots that bend.
Old 09-03-2007, 08:09 PM
2fastWS6's Avatar
explain how these work.Do they come straight and you can bend the boot where you want it and it will stay there?
Thanks
Old 09-03-2007, 08:38 PM
chuckyt1's Avatar
Yep, that's how they work... Here's a pic, #2 XS Primary and MSD wires.
Old 09-03-2007, 09:26 PM
2fastWS6's Avatar
Thanks for the pic, Chuckyt1. Has anyone ever used the Thermo-Tec heat shields? Is this a problem with all LTH's or just the XS headers?
Old 09-03-2007, 09:28 PM
Quickin's Avatar
You should be able to rotate the end of the spark plug wire that is attached to the coil, rotate it until the wire is off of the header.
Quick Reply: spark plug wire touching header.HELP
