93-97 pedal assembly in an ls1?
are lt1 and ls1 6spd pedal assemblys interchangeable? does it need modification or will it just bolt right in? i have a 2kss that needs a pedal assembly.
The pivot point on the clutch pedal is different. If you use an adjustable master it might work, don't know for sure. There was a thread on here that had photos of the two side by side.
