Bad luck!!
Bad luck!!
Hey guys just finished up putting the trans back in after my Textralia install. I'm pretty hyped about it.... then I started thinking....
When the RAM HD was put in.... they put a spacer on the slave!!
I didn't remove it!!!
My question is: Will I have to pull the trans out to remove the spacer in order to use this Textralia clutch?
Thanks
Thanks
Unless you have an adjustable master cyl you may want to take the spacer out. The reson being is that the spacer may cause the TO bearing to rest againt the pressure plate fingers, which will cause quick wear down.
See... I'm hoping its not resting on it. I've still got to tidy up some other stuff before trying it out. Which will be tomorrow. I'll try it and as long as its clearly disengaging/engaging I may give it a shot. I really really don't want to pull it back out, but I will if it doesn't work out.
And no... don't have an adj. master
